andrew j cox
Thread starter- Joined
- Feb 11, 2015
- 149
hey Guys, I just did the head on a yammy 50 4 stroke it’s an 02 f50, with the timing and I don’t want to yank the flywheel off I have set the top pulley up with arrow on block, both rockers on number one are slack, the flywheel side the timing marker is sitting on T I assume TDC, there are numbers on the timing tape to the right of the T 30,35 some other notches, where do I set it and when the timing connected what mark am I lining it up with, just need to check the carbs and change the plugs, with some it will run
