Year of motor?
jimyoung
I have an Evinrude...#jooo2488 and 4055 4c....age, any quirks/hints etc about this engine....It has had an extension installed ...makes it a long shaft..
I also have a midsection/lower end with the following # 1880 3m-e01838, can the parts be used on the other engine?
Thanks for any help.....
jimyoung
Re: Year of motor?
I must have read the # wrong.....this is a late 80s or early 90s motor.....
bankerjohn
Re: Year of motor?
Another guess ... 40554 = 1975 40hp Evinrude ??
ezeke
jimyoung
Re: Year of motor?
YUP!.....that is what it looks like......so this motor worth anything? It has an extension to make it a long shaft, I need a short shaft, worth the work....it does run ok. It is set up for remote control vs tiller
ezeke
Re: Year of motor?
A new 40HP is in the $5,000. range. An older, clean, running motor of similar power will usually bring around 10% of that, more or less.
The 40 is a good motor for small faster inflatables, so you should not have much trouble finding a buyer, but be prepared to show compression, spark and ability to run and shift gears.
