Re: year suzikie 30
Please describe the info you need from the manual. I am almost certain you will NOT find a manual giving instructions on removing the oiling system (VRO....which is actually an OMC term)what Suzuki calls "oil injection". I eliminated mine while the engine was disassembled. Removed the emulsifyer(sp) connections, drilled out the injection tubes, tapped and installed threaded plugs and epoxied over the holes on the exterior. Except for the homemade plate over the oil pump attachment and the mounts for the oil tank, you can't tell there was ever an oil injection system.<br /><br />To clean the filter in the oil line....1)unbolt the trim piece the rope pulls through 2)remove the three bolts that hold the oil tank on 3)holding the rope out of the way pull the oil tank away from the motor and wire it to something in a position that the oil line exiting the bottom is accessable, you may have to get the wires to the tank level switch and the switch on the filter out of the wire holders 4)four (or was it three)little screws on the filter need removed and the filter splits...the gasket and the little nuts and screws can be a pain. Have rags or paper towels handy, hemostats on the soft oil line helps. Clean filter and reassemle. Continue running you oil in the fuel tank until oil use from the injection tank is certain. <br /><br />Seems strange you found performance by working on the oil injection. Did you work on the carbs?
