yellow wires from stator? flywheel nut torque?
qflex1115
i am installing a new stator on a johnson 130 1999, the new stator has 2 plain yellow wires with no grey does it matter wich one hooks up to the grey wire coming from the regulator? and what is the flywheels nut torque spec for my motor? a quick response will be GREATLY appreciated as i have to have this boat out of my driveway because of HOA!!! thanks in advance.
Joe Reeves
Re: yellow wires from stator? flywheel nut torque?
When no yellow/gray wire exists and both wires are yellow, it does not matter which yellow wire is connected to the rectifier lead.
I believe the flywheel nut torque remains at 105 foot pounds as in the past. However, Hopefully someone will jump in here to verify that figure.
qflex1115
thanks Joe. for the quick reply thats what i was thinking, i just wanted to make sure. also, would you happen to know the max spark advance for my motor? j130pleed?
