Yems v8 water spewing in engine compartment
thewoozer
Pretty sure water isn't supposed to be coming out here... Need some suggestions and or thoughts as to what it could be.... First run of the year was fine all last summer... I am a little slow so use little words please lol
And and all help would be greatly appreciated
Ayuh,..... Welcome Aboard,....... How did you winterize it,..?? or did you at all,..??
flashback
Yep that manifold is split wide open, lets hope there's no more surprises
thewoozer
I am not sure how it was winterized, I had a friend that is a marine mechanic do it... By the sounds of things, not well.... Spit manifold... That sounds really bad... The other side is leaking as well, but in drips
flashback
May want to get your friend to take a look. I can't be certain it's split but that's how it looks..
thewoozer
Next question.... Launch is about 1km away from where boat is to get it back on trailer... If I run it slow will it do more damage, can I get away with not paddling
flashback
Well when you determine if they are cracked from freeze damage you could have more problems than that so don't rush out and buy manifolds just to find out later that the engine block is also damaged..
flashback
Better check your engine oil and be sure it doesn't look like a milkshake, if so drain it asap.
thewoozer
Already checked oil... It looks clean... Hopefully that means engine block could be ok (fingers crossed šŸ¤ž)
Any clue why aftermarket parts can replace?
Ayuh,..... Not sure what this, ^^, means,....
But I can tell you that replacement parts for Yamahas don't exist in the US,....
You'll have to adapt parts for other's motors to work on yer Yamaha,....
I've heard Merc manifolds can be adapted,...
Get a tow to the dock
Find a new mechanic
Pressure test your engine cooling system
If you are lucky and it's just the manifolds, buy a lottery ticket
Good luck on finding manifolds
