A friend is offering me a '95 Four Winns Fling w/trailer that has been garage kept. The trailer has a new mounted spare and is in great shape. The hull and seats are in excellent shape. He wants $500 for the boat and trailer because he has to move and has another boat, two motorcycles and a trailer to move.
The engine was overheated by another person and he tore down the engine and honed the 2 cylinders on that side and replaced the rings. It runs fine at idle, but under load the engine overheats. It has a water strainer on the engine. He added an inline 12v water pump that does nearly 300 gallons an hour to ensure water is going through the engine.
We strongly suspect the fuel pump as the problem since it mixes the oil into the 2-stoke engine. The oil tank has a primer bulb that is rock hard, so it seems that the oil is not flowing into the engine. It's an easy test to mix a tank of gas/oil to see if it runs fine that way.
I think the hull and trailer are worth more than the $500. There is a guy in NY that sells rebuilt OMC powerheads with a year warranty for the jet drive for under $2,000 I think.
Is this a deal I should jump on?
