alex3012red
- Joined
- Nov 20, 2006
- 65
93 merc. 3.0 done a head job, new valves,gasket, put it in the water ran fine next day had a little water on #4 cyl., enough to have a bad idle,and to start making my oil milky on top end.my question is the water coming from the riser did not replace that or manifold, how can i check them for leaks, i will do the block pressure test any suggestion on how to do are welcome, i did read Don S. water in oil (thanks Don for your great help to all). just wanted to get more details on how to. I don't winterize the boat,(california) but it is in saltwater most of the time. 99%
I done the head job beacause it had injested water!
also changed water pump and thermostat and housing.
