tschamp20
Thread starter- Joined
- May 10, 2006
- 317
this makes the 8th problem in 9 trips ive taken w/ this motor.
today after i launched got to the end of the no wake zone trottled her up ran strongest it ever has ran.even got 5000 rather than the normal 4800 rpm.about 30 seconds later i slowed down to hook up depth finder and noticed a miss.turned around to head in since i was so close.then i noticed the telltale stopped flowing completely.shut it down.had steam from the telltale.i made the decision that since i was only about 500 yards from dock to start it up and get in. but to my surprise it was peeing again,for about 10 seconds then stopped again.it ran that last time for about 15-20 seconds w/ no pee.
after getting to dock i checked the heads w/ my hand and it was BLAZIN HOT!
when i got home checked compression,110-115 on all four.
found #2 plug electrode was pushed down,which i assume caused the miss.
put in the surface gap plugs i have as spares and it started right up,and peeed.shut it back off.
im gonna drop lower unit tomorrow night to check impeller.
obviously the heat sensor is defective.
could a failed impeller cause the intermittent flow that i saw?
as a reminder this is a newly rebuilt 1973 johnson 115.every ignition part is new,i mean everything!
all passages were cleaned out as well.
any other things i should check?
oh yeah its also a new thermostat
thanks for reading ,DOUG
