Yellow Yota
Thread starter- Joined
- Jul 23, 2009
- 122
Alright. I've seen a lot of plug related threads lately, and the general consensus seems to be that you have to run marine plugs in our boats.
My question is: what makes a plug "marine"? I mean if you get the correct size plug, in the correct temperature range, and with the same electrode material (platinum, iridium, whatever), what else is there?
Other than the regular answer of needing a "marine" plug. I'll be more than happy to spend five times as much if there is some legitimate info or specs that make sense.
Not trying to ruffle feathers by any means. I just see the same answer of what plugs to run without much backup other than "because it's what the manufacturer specs". I'm looking at this like the oil threads. V/P lists different oils being approved than Merc does. When it's the same motors. Is there more to the plug story?
Thanks,
Chad
Thanks,
Chad
