You really need to remove the gearcase to chage the waterpump?
BigB9000
Im starting to work on my 78 115hp and the manual says to remove the gear case. Is this an easy job? the manual says use this greas on that, then use this type of grease on this, etc etc etc.
look like a freakin pain in the butt.
anyone done it have any pointers?
jay_merrill
Re: You really need to remove the gearcase to chage the waterpump?
Since the water pump is an internal component, which rests on the top of the gearcase, yes you need to drop the gearcase to change it. Its actually not all that difficult to do.
Vic.S
Yes!
JoLin
I'm still a newbie, but it isn't that bad. Follow the manual instructions to the letter (including throttle lever placement prior to disconnecting the shift rod and unbolting the lower unit) and you'll be fine. Helps to have an assistant when you're putting the lower unit back on. Often you have to rotate the crankshaft a fraction of an inch at a time (via the flywheel nut on top of the motor) before the driveshaft will slide up into the powerhead.
Don't let the grease and sealant requirements drive ya crazy. Nobody in my area carries the "OMC" stuff.
For OMC triple-guard grease and "moly lube" use any marine type grease. Quicksilver is readily available, and you'll use it for lubricating other things on the motor, too.
For OMC Gasket Sealing Compound, use Indian Head gasket shellac. Comes in a plastic bottle with a ball applicator. Available at any auto parts store. It's messy, but turps will take it off your hands.
For OMC Adhesive M sealant, you can use Permatex # 2, also available at the auto parts store.
