gunnymartin
Thread starter- Joined
- May 30, 2009
- 6
O.K. save the laughs and the ridicule to the end. It will get better.
I don't know for sure I know how to start my boat. It's a IO mercruiser in a dixie. There is a normal ignition switch with a couple levels of switch. The first half turn gives electricity to the accessories (gauges, etc) then the second step is to start the engine.
The throttle is on a long handle next to the Drivers seat. The throttle cable pulls when I push the lever foward or backward. There is a button there that is labeled "bow up" and "bow down". Those raise and lower the outdrive when pushed.... Obviously to change angle of engine. There is a button that is labeled "trailer" that when I push it the outdrive raises to help put it on the trailer without dragging the propeller. There is a button on the bottom where the handle pivots that says "throttle only" that seems to release the handle from cables that appear to be attached to the outdrive.....? putting it in neutral????
There is a button on the handle right where my fingers go when the grip is held that is unlabled.
My question is,
Some tractors have to be in neutral to start.
Some cars have to be in park to start.
Some cars have to have the clutch pushed to start......
So, how do I start my boat?
Thanks for the ridicule and for the help.
My question is,
