CApTaInGoOfy
Thread starter- Joined
- Aug 17, 2015
- 91
I've noticed that the steering is stiffer this season after I took the boat out for the first time. I greased the steering cable with 2-4-C and when I unhooked the motor from the cable the steering wheel turned like butter. When I try to turn the motor by hand disconnected from the steering cable it is stiff. I found that there is a zerk fitting that I tried to pump grease into via my grease gun but it seems clogged up as it just pumps it out. After cleaning up the area I than turned the motor by hand and noticed from the zerk fitting it seemed to squeeze out a little grease and then stop. Was going to replace the zerk fitting but it is totally smoothly round. Not sure how to remove this or even how to unclog the darn thing. Took a heat gun to it thinking maybe if I heat the grease up it'll give a little, nothing. Any help would be awesome.
The motor is a 1983 Chrysler 45HP
Untitled by Jae Cha, on Flickr
