Zinc anode attaching hardware (Stainless OK?)
allingeneral
I have a fiberglass boat used in brackish to salt water. I am replacing the sacrificial anodes on my Volvo DP-SM lower units. What kind of bolts should I use to ensure that my aluminum lower unit does not corrode at the attachment point?
I have some stainless steel screws that I was planning to use, but after a little research, I have found that Aluminum and Stainless Steel are far apart (pretty much opposite ends) on the galvanic scale, which could result in corrosion of the aluminum.
What material should I use for the attachment hardware? What are the stock fasteners made of that are used on the Volvo outdrives?
Thanks for reading.
Don S
Re: Zinc anode attaching hardware (Stainless OK?)
Stainless is what Volvo uses.
allingeneral
Thanks Don. You're a wealth of knowledge, my friend!
