thumpar
- Joined
- Jun 21, 2007
- 6,138
Re: Zinc Anode - Bias Adjustment Q
I think the original one that the OP is asking about is broken off. It happened to me on a boat so you have no place to start unless you have pictures or some other way of knowing where it was.Question from a Newbie...
It works as a Trim Tab on an Aileron or a Tab on a Rudder works if not mistaken.lane: They are there to make slight adjustments to flight to prevent flying skewed through the air.
When misaligned, you are spoiling the water that is passing the drive, and by making slight adjustments port or starboard, you are eliminating the drag on the steering correct?
If the new one is similar to the one that is on it currently and there is no issues with steering now (or before the damage), wouldn't it save a lot of time and frustration by crib marking the one that is there before removing it? Like measuring a tie-rod before removing and replacing it.
Seems like it wouldn't be a "complete shot in the dark" and it should be close providing that it is close to the same as the one being removed or am I missing something?But they would have to very similar in thickness, shape, and length.
