Zinc Chromate will this work?
ezmobee
Re: Zinc Chromate will this work?
Since it's ZC it should work. The stuff I used was definitely not a "filler" as you only really use a light dusting of the stuff. Maybe that's the difference. I was able to find Duplicolor's etching primer at Pep-Boys for only like $6.
thrillhouse700
OOOO duplicolor etching primer is zinc chromate?
Thrill,
This is a filler primer which provides a thicker coating to cover fine scratches and such. You will need to sand this primer lightly before painting. If you intend to fill some surface imperfections and want a more mirror like finish then use the VHT. If you just want the chemical bonding piece then just use a plain ZC primer.
ezmobee
Not sure it was ZC but is was chromo-something and it definitely specifically said for bare aluminum so that was good enough for me.
Slip Away
I forget the brand (they were bought out) I used, but when I repainted my Volvo drive, the ZC that was at Boater's World came either in green or yellow.
I bought the yellow. You know, that contrasting color thing.......
It worked great, stayed on better than the actual outdriove paint did.
thrillhouse700
What kind of paint are you guys using on your outdrives?
