LAWDOG2001
Thread starter- Joined
- Jul 5, 2009
- 17
I have a 2001 Merc 4.3L EFI with Alpha Drive. Needed to change out zincs. Guy at the counter gave me five zinc anodes. A flat one for the upper Alpha Drive, one over the hydraulic connector box, two for the pistons and one, not so obvious as to where it goes. It's the Quicksilver Anode 806105Q1. Web says it's for the bearing carrier. Manual shows a bearing carrier behind the propeller DEEP inside the Lower Unit Housing. Is this where I'm supposed to place this Zinc?? How do you get into that? I pulled off the propeller nut, tab washer, spline washer and propeller (btw, didn't find a continuity washer behind the spline washer) and all I see now is a thrust hub. Now what? Anyone have a clue? Am I even going in the right direction with this? Thanks!
