Zip Board?
JoeCrow
Back in the 70's we had a hollow, plastic "board" that we towed behind our boat
I believe it was called a "Zip Board"
It was about 4' long and 2' wide and about 5" thick
It was drilled so that water would go in the front and out the back adding stability and had a tri-hull or pontoon style bottom
It was a lot more fun than a tube and much more controllable
Does anyone know if they still make these or if I have the right name?
I've been trying to find one without much luck
tashasdaddy
Re: Zip Board?
watch ebay, see if you find one. seriously doubt they are still around.
JoeCrow
Re: Zip Board?
I'll keep checking,
I just wanted to make sure I had the right name
Thanks
mthieme
Re: Zip Board?
For kicks, I did a google search and only had one hit.
It was a reference to finless surfboard in Australia.
Best of luck in your search!
JoeCrow
Re: Zip Board?
I got the same,
that's why I thought maybe I had the wrong name
I was hoping someone else remembered them and new the correct name, if zip board isn't right
Thanks
