Zodiac Semi-Recessed Value Replacement
GreyStoke
Hi Folks, after doing some on-line research, I discoverd that the SRV (semi-recessed valve) has 2 assemblies for the CADET 285 FastRoller; the top (part#Z60216) consists of cap etc.; the bottom (part #Z60217) consists of the green pop-up value and its seat. Well, somehow I busted the pop-up and the seat below self-destructed. Fragments of the seat are now in the starboard tube. I just wanted to confirm that this now is a job for the dealer. I would expect the dealer tech would have to delaminate the fabric ring around top assembly and remove the entire SRV; retrieve broken fragements which could potentially puncture the ZODIAC; install a new lower assembly; and glue (re-laminate) the fabric ring back on to the tube. Am I correct in this assumption? This situation does not strike me as a "do-it-yourselfer".. I expect at least 2 hours labour and perhaps $75 in parts bringing this job in at around $300 (CDN). Does this sound reasonable? Thanks folks
