M
Mc Tool
replied to the thread
Kicker motor vs towing
just been doing this as I have a Honda main engine ,and a 6hp Zuki aux , both 4 stroke . I have it set up so either motor can run off...
Jul 21, 2025
S
searay250
2005 Mercruiser MPI 5.0L misfiring(?) when in gear, idles fine
Thanks for saying this! I appreciate the pep talk and the reassurance that at least one person appreciates all the detail... sometimes...
Jul 21, 2025
2016 Mercruiser 6.2L ECT DTS Axius Cooling System Issue
I soaked cylinder heads in oxalic acid in the past I have also used 20:1 water to muriatic acid
Jul 21, 2025
K
kenny nunez
alpha 1 won't go into reverse
Another place to look is the pocket that the slider travels in for reverse in the upper gear housing. Crud will build up in there and...
Jul 21, 2025
C
cyclops222
New Winch or Winch Strap?
Non metal rope / cable never kinks. Flat webbing lays flat with no care at all.
Jul 21, 2025
M
Mc Tool
Yeah ideally a pair of motors makes good sense ,specially if your going a good distance. I am often surprised ( well not any more ) at...
Jul 21, 2025
C
cyclops222
All engines MUST MUST use the same type of gasoline !!!!!!!!!!!!!!!!!!!!
Jul 21, 2025
M
Mc Tool
Have you ever had to fit the kicker in rough conditions ? I dont even like the idea of trying to refuel a small motor let alone trying...
Jul 21, 2025
C
cyclops222
reacted to
airshot's post
in the thread
with
Like
Been a boat owner for over 60 years, always had backup propulsion just in case. On smaller boats a set of oars will work ( yes, folks do...
Jul 21, 2025
J
Jeff J
1997 Honda BF40A trim fluid check?
The circled bolt should be the fill level check.
Jul 21, 2025
A
airshot
reacted to
roscoe's post
in the thread
with
Like
My 15 hp kicker is bolted to the transom, no bracket, always is on the boat. Used for trolling or emergencies. The other boat , 4 hp...
Jul 21, 2025
reacted to
alldodge's post
in the thread
MC-1 Drive Dog failure?
with
Like
I'm not there but hide sight is always 20/20 If it was mine I would want to determine if a new SEI drive will fit but that's 2K The...
Jul 21, 2025
A
airshot
Jul 21, 2025
9
99yam40
question on Yamaha ELG 40 carb rebuild
I agree with Bosco, if it mattered, they would make them to only fit one way or give info on how they need to be installed. And just...
Jul 21, 2025
M
Mc Tool
It rained on my fresh, wet paint!
Yeah dunno 'bout that Scott , I should be up there with the wizard of Oz then........ but Im .....not :LOL:
Jul 21, 2025
