C
Cdn20valve
reacted to
vroom ZOOM's post
in the thread
454 mag mpi chuggles/stalls
with
Like
Well everyone, it is FIXED!!! FINALLY! you are not going to believe what it was... The fake injectors had the pins in the connectors...
Jul 22, 2025
replied to the thread
Throttle movement but no increase in engine rpms
secondaries on a rochester open by air flow from the engine. there is no mechanical connection to the rochester secondaries. if you do...
Jul 22, 2025
B
Bill4452
1998 Volvo/OMC - When shifting to forward, the motor stalls. It runs fine on muffs.
I pulled the prop and there is no string wrapped around the shaft. I tried taking the exhaust hoses and clamps off, but there was not...
Jul 22, 2025
roscoe
Kicker motor vs towing
No I haven't. Dad used it on a few trips and did have to use it once and put it on the transom, but not in rough water. His little...
Jul 22, 2025
Fun Times
reacted to
tpenfield's post
in the thread
2016 Mercruiser 6.2L ECT DTS Axius Cooling System Issue
with
Like
This diagram from the parts list shows slightly different routing to the poppet valve (I believe). .
Jul 22, 2025
Fun Times
More so need to go by the manual vs a parts guide as parts catalog is usually found off in its routings and then since your manual was...
Jul 22, 2025
B
Bailman66
posted the thread
90hp Nissan outboard no spark on all 3 cylinders
in
Honda & Tohatsu/Nissan Outboards
I was starting up my 90hp nissan for the first time in years it was running great and i called my self checking cylinders and pull the...
Jul 22, 2025
tpenfield
Jul 22, 2025
Fun Times
Yes, thought you had the manual too but always worth a second scan through. ;) Since you're up that is. :D good night on my end. :sleep:
Jul 22, 2025
Fun Times
reacted to
tpenfield's post
in the thread
with
Like
I am up early this AM. I think this is the page you are referring to . . . . .
Jul 22, 2025
B
Bailman66
No spark 90hp nissan
I pulled top spark plug wire off while motor was running great 90hp nissan outboard engine shut down immediately now wont start no spark...
Jul 22, 2025
tpenfield
Jul 22, 2025
Fun Times
If you haven't seen it yet, i found your service manual and it shows the water flow and suggests the strainer (F) I mentioned earlier is...
Jul 22, 2025
jimmbo
How to restore this 1961 hull?
Jul 22, 2025
salty3rd
2005 Mercruiser MPI 5.0L misfiring(?) when in gear, idles fine
I would remove the distributor cap, have someone crank the engine over while you are looking at it for a second or two and verify the...
Jul 22, 2025
