replied to the thread
2016 Mercruiser 6.2L ECT DTS Axius Cooling System Issue
Ted, Im not an expert, just trying to wrap my head around some of the goofy crap from Fond du Lac do you have the schematic of the...
Jul 22, 2025
2006 5.7L Mag Overheating
Check the hose from the bell housing to the transom plate, might be collapsing
Jul 22, 2025
J
Jesse Walter
posted the thread
in
Mercury MerCruiser Sterndrives & Engines
I've have another couple threads involving my work on swapping a Bravo 3 drive onto my Bravo 1 boat. All and all that's a big success...
Jul 22, 2025
Throttle movement but no increase in engine rpms
Blades are thinner so less drag but as Scott mentioned I think your motor has lost some HP
Jul 22, 2025
redneck joe
2025 NFL/CFB News and Nonsense
Jul 22, 2025
redneck joe
Random
Jul 22, 2025
R
How to restore this 1961 hull?
Well ---If it was built with balsa core and now has all these cracks.----The balsa core may be rotten and the hull may fail when hitting...
Jul 22, 2025
dingbat
question on the starting a "2 cycle Merc" sticky
Which you often did….lol Imagine a 67 Galaxy 500 getting 35 miles to the gallon, no component failures and still burning zero oil at...
Jul 22, 2025
tpenfield
Well, I’m also thinking the manual is the more correct version, as the only way for raw water to exit the system is via the risers. The...
Jul 22, 2025
4.3gxi bad temp sensor?
doubt its the temp sender causing the issue. did your temp follow the sender or stay with the motor, your post is not clear there...
Jul 22, 2025
ID motor
the motor was dependable when new. however used motors rely more on how they were maintained. as for the age, looks like mid 90's
Jul 22, 2025
easiest un-obstructed access to the bottom of such a light boat is to use the two transom eyes and the bow eye and hang the boat from...
Jul 22, 2025
Grub54891
Where does the hose go?
it attaches to the airbox as stated. It goes to the carb and the vacuum sucks any residual fuel back to the motor and burns it up...
Jul 22, 2025
U
utfyrfytr
posted the thread
ID motor
in
Non-Repair Outboard Discussions
Can someone ID this motor for me? Approx year and dependability?
Jul 22, 2025
M
MikeSchinlaub
Did they also do transom and stringers? It doesn't really add any strength. It's main purpose is to seal the bottom. Gel is porous, and...
Jul 22, 2025
