Scott06
replied to the thread
2005 Mercruiser MPI 5.0L misfiring(?) when in gear, idles fine
Agreed probably the button in top of cap is not making contact with rotor. either that or cap is cracked and leaking spark to ground. so...
Jul 22, 2025
H
Harkonnen
2005 J115PLSOR weird oil leak
Fair enough, I was keeping it under 3K per break-in instructions. I do suspect I have excessive crankcase pressure issues, because...
Jul 22, 2025
Stinnett21
Kicker motor vs towing
The issue you bring up with ingesting water on a non running engine is something I hadn't thought of. With a non running alpha 1 gen 2...
Jul 22, 2025
99 Volvo 5.0GL
3-8 is low pressure A VP high pressure pump is 50-60 psi
Jul 22, 2025
D
dremison
reacted to
Fun Times's post
in the thread
Lost All Steering on Bravo 3 Outdrive
with
Like
$$$.$$ saved too by making it within your pay grade 😉🙂 Nice job.👍
Jul 22, 2025
T
tphoyt
reacted to
redneck joe's post
in the thread
Random
with
Like
Jul 22, 2025
B
Bhuie
99 Volvo 5.0GL
I have acquired a pressure test kit for the fuel pump. Mentioned above was 3-8 PSI. Would that be considered high or low pressure...
Jul 22, 2025
R
1955 Evinrude Fleetwin 7.5hp carb kit?
When shifting on a stand you must turn the propeller when operating the shift handle.
Jul 22, 2025
Njsloans1
fuel leak from infloor tank
Do you have an aluminum or plastic tank? My old boat had an aluminum tank and where the fuel pickup bolted on, the tank completely...
Jul 22, 2025
Welcome With it only happening when the bow is raised, look at the tank fittings and hoses You will have the main tank fill hose, tank...
Jul 22, 2025
4.3gxi bad temp sensor?
That sounds like the IAC as Scott mentioned
Jul 22, 2025
F
fleetwinner
Those are the numbers I had in mind, but my question is what does it tell me if there's too much deviation or they are underpressurized...
Jul 22, 2025
F
fleetwinner
Prop turns correctly in all gears when it will get into them, free in neutral and locked in drive and reverse. It's just that sometimes...
Jul 22, 2025
H
happychapboater
The coolant temp followed the sensor when I swapped them. The main problem has been to get the engine to not stall after 10-15 seconds...
Jul 22, 2025
P
Ponhook John
posted the thread
in
Boat Topics and Questions (not engine topics)
i have a fuel leak coming from somewhere in my fuel tank when my bow is raised. i filled up my new to me 1991 Sunbird 18.5 Bowrider...
Jul 22, 2025
