A
airshot
reacted to
Mc Tool's post
in the thread
Kicker motor vs towing
with
Like
Have you ever had to fit the kicker in rough conditions ? I dont even like the idea of trying to refuel a small motor let alone trying...
Jul 22, 2025
G
gcarmich
replied to the thread
WOT RPM Low. MAG350 MPI B3
Does the fuel pressure change with RPM? My crab cap is 2yrs old.
Jul 22, 2025
A
airshot
New Winch or Winch Strap?
Gotta agree here, worked with steel cables for many years, never enjoyed using it. Flat strap for boat trailer and synthetic winch rope...
Jul 22, 2025
jimmbo
question on the starting a "2 cycle Merc" sticky
I remember the 73 Fords, missing the lower Door Skins, after one or two years, less than 6 Months if in the Salt Belt
Jul 22, 2025
J
jimmwaller
Question about Bravo 3 conical clutches
ah okay, that's cool. So basically total engagement from the moment it touches, that's good to hear. So if my gears are engaging...
Jul 22, 2025
W
wjhuskey
How to restore this 1961 hull?
I'm not sure about stringers but pretty sure they didn't touch transom but they inspected it and then replaced the floor and then...
Jul 22, 2025
M
mike_i
fuel leak from infloor tank
Is your tank aluminum? Is it foamed in?
Jul 22, 2025
C
cyclops222
reacted to
racerone's post
in the thread
with
Like
Well ---If it was built with balsa core and now has all these cracks.----The balsa core may be rotten and the hull may fail when hitting...
Jul 22, 2025
C
cyclops222
reacted to
MikeSchinlaub's post
in the thread
with
Like
Did they also do transom and stringers? It doesn't really add any strength. It's main purpose is to seal the bottom. Gel is porous, and...
Jul 22, 2025
C
cyclops222
reacted to
Chris1956's post
in the thread
with
Like
I had a Crestliner of about that age, years ago. The hull was cored with Balsa wood. It was mush in the 70's. If your hull is cored...
Jul 22, 2025
W
wjhuskey
reacted to
racerone's post
in the thread
with
Like
Jul 22, 2025
C
cyclops222
Throttle movement but no increase in engine rpms
The secondary airflow sensor and mover are too draggy at the cross over point ?
Jul 22, 2025
C
cyclops222
1998 Volvo/OMC - When shifting to forward, the motor stalls. It runs fine on muffs.
Is the idle speed too low ? Is it set too lean ? A little bit of both conditions ?
Jul 22, 2025
R
Major work on modern cars is not done by shops anymore.-----Labor costs too much and skilled mechanics are not abundant.----Overhaul it...
Jul 22, 2025
H
happychapboater
4.3gxi bad temp sensor?
I replaced the IAC first and that hasn’t corrected the issue unless it was a bad IAC. I also swapped IAC between the two motors and it...
Jul 22, 2025
