replied to the thread
WOT RPM Low. MAG350 MPI B3
you test fuel pressure with a mechanical pressure gauge at the schroeder valve verify the crab cap is in good order. get a new one if...
Jul 22, 2025
G
gcarmich
reacted to
Scott06's post
in the thread
with
Like
this thread has the indexing of dist https://forums.iboats.com/threads/mercruiser-5-0-mpi-distributor-issue.690321/
Jul 22, 2025
FLATHEAD
2025 NFL/CFB News and Nonsense
Losing to the Eagles in the Super Bowl left an effect on Mahomes😁😎😁😁
Jul 22, 2025
F
fleetwinner
posted the thread
1955 Evinrude Fleetwin 7.5 Carburetor
in
Johnson & Evinrude Outboards
Hello I am looking for instructions on cleaning my carburetor. My slow speed needle valve adjustment does seemingly nothing at both low...
Jul 22, 2025
nola mike
2005 Mercruiser MPI 5.0L misfiring(?) when in gear, idles fine
Please don't do that
Jul 22, 2025
Scott06
Jul 22, 2025
nola mike
1. Those plugs look horrible. Wouldn't surprise me if they didn't fire. But you said you replaced them 2. Post 29, you have a pic with a...
Jul 22, 2025
G
gcarmich
Haven't compression tested since new heads/valves. Can do soon. Props are original. Is fuel pressure available through VesselView...
Jul 22, 2025
Lou C
1998 Volvo/OMC - When shifting to forward, the motor stalls. It runs fine on muffs.
Those hoses can be tough to get off, I use picks made to remove radiator hoses & silicone spray. Slide the lower hose down the Y...
Jul 22, 2025
F
fleetwinner
1955 Evinrude Fleetwin 7.5hp carb kit?
Thanks for the info, I'll do the test today. Still thinking the carburetor needs to be cleaned out or rebuilt and am struggling to find...
Jul 22, 2025
C
question on the starting a "2 cycle Merc" sticky
Gee, remember the rust on the rocker panels in the 60s and 70s? Cars are just about throwaways today. When they finally break, they...
Jul 22, 2025
nola mike
reacted to
Scott06's post
in the thread
with
Like
Agreed probably the button in top of cap is not making contact with rotor. either that or cap is cracked and leaking spark to ground. so...
Jul 22, 2025
C
cyclops222
Kicker motor vs towing
Sudden bad wind and waves. I beach the boat and lay on the ground.
Jul 22, 2025
C
2005 J115PLSOR weird oil leak
Maybe the Pulse Limiter is leaking. It is very low on the block.
Jul 22, 2025
C
cyclops222
reacted to
roscoe's post
in the thread
with
Like
No I haven't. Dad used it on a few trips and did have to use it once and put it on the transom, but not in rough water. His little...
Jul 22, 2025
