ESGWheel
replied to the thread
2005 Mercruiser MPI 5.0L misfiring(?) when in gear, idles fine
After some good sleep, well not really > I was bothered by not picking up on your unique wiring numbering, so perhaps a little of that...
Jul 22, 2025
F
Fj40fiji
I didn't want to restore this 1997 Islander this summer
I wire wheeled and acid etched till I had these little white specks of corrosion left that wouldn’t come off. I decided to use the tip...
Jul 22, 2025
C
Kicker motor vs towing
Gee, one can run 50::1 premix in a 4 stroke motor. Vice versa is very bad however.
Jul 22, 2025
M
MikeSchinlaub
reacted to
Scott Danforth's post
in the thread
fuel leak from infloor tank
with
Like
the hoses could have deteriorated, the new hoses are more tolerant of E10 than the hosed that were in your boat 35 years ago, however...
Jul 22, 2025
S
saltchuckmatt
2005 J115PLSOR weird oil leak
You need those special nylon ties....the ones that are more rounded. It won't come off again. I'm pretty sure Racer mentioned that.
Jul 22, 2025
WOT RPM Low. MAG350 MPI B3
it could be a throttle linkage issue it could be a fuel system issue it could be a wrong prop issue it could be an ignition issue what...
Jul 22, 2025
G
GlasV162
posted the thread
Malibu Flightcraft Barefooter
in
Malibu Boats
Hello, It's been a long time since I've been here. We're looking at a 1994 Malibu Flightcraft Barefooter outboard. It's my understanding...
Jul 22, 2025
Scott06
Couple of things I would look at - first yes of course it could be the linkage make sure it is opening all the way Verify firing order...
Jul 22, 2025
R
1955 Evinrude Fleetwin 7.5hp carb kit?
These early 7.5 HP motors have a poorly designed head gasket.--No metal ring.-----A wise owner would do a compression test !
Jul 22, 2025
R
Excessive crankcase pressure is not possible !
Jul 22, 2025
G
gcarmich
posted the thread
in
Mercury MerCruiser Sterndrives & Engines
My Mag 350 MPI only hit 3870 RPM with throttle lever all the way down. Clean hull. New valves, heads, injectors. Could it be a...
Jul 22, 2025
Scott06
Throttle movement but no increase in engine rpms
Did it ever run at a proper WOT RPM or did this happen concurrent with the prop swap ? In addition to the compression check would...
Jul 22, 2025
D
DeepCMark58A
I am not putting a kicker motor on my pontoon or mastercraft, not needed.
Jul 22, 2025
T
tphoyt
I think of compression as if it’s blood pressure. It’s the first thing they check when you go to the doctor to determine your over all...
Jul 22, 2025
Jul 22, 2025
