Scott06
reacted to
Fun Times's post
in the thread
Bravo 1 transom plate
with
Like
Yes they both share the same part number and where used description. (Mercruiser 8M0138839 Inner Transom Plate Inner Bravo and Alpha...
Jul 22, 2025
redneck joe
replied to the thread
Kicker motor vs towing
Having a cell phone and having coverage are two different things.
Jul 22, 2025
redneck joe
reacted to
JimS123's post
in the thread
with
Like
Calm winds, mid day Friday, full sunshine, the morning weather report said seas less than a foot. At the launch ramp the VHF weather...
Jul 22, 2025
redneck joe
reacted to
FLATHEAD's post
in the thread
daily music fix
with
Like
Rip ozzy https://g.co/kgs/agXyRiQ
Jul 22, 2025
C
cyclops222
reacted to
Don S's post
in the thread
Engine stalls when shifting back to neutral
with
Like
Re: Engine stalls when shifting back to neutral The lower shift cable is beginning to get stiff and causing the shift interrupt switch...
Jul 22, 2025
FLATHEAD
Ozzy Osbourne
I think just about everyone back in the day owned the Paranoid album.
Jul 22, 2025
Rear water port near deck
Welcome I have an idea but first, what boat is in pic? There should not be hot water coming out of it while running. It might be a...
Jul 22, 2025
4.3gxi bad temp sensor?
Which other sensors have you swapped? Measure 5V reference voltage on the MAP or TPS What voltages does Techmate show for TPS and...
Jul 22, 2025
Fun Times
reacted to
Grub54891's post
in the thread
Ozzy Osbourne
with
Sad
https://www.yahoo.com/entertainment/articles/ozzy-osbourne-black-sabbath-frontman-181737802.html
Jul 22, 2025
WOT RPM Low. MAG350 MPI B3
Scott, it's a Merc so most likely 43 psi, Volvo Penta is 50-60 FP can change a few psi, like 40 at idle and 43 or so at WOT What are...
Jul 22, 2025
R
RMassa187
I know this is old, but I have the same issue. Replaced the lower shift cable but the problem persists. I can move the lower shift cable...
Jul 22, 2025
C
Cap Doug
posted the thread
in
Mercury MerCruiser Sterndrives & Engines
Does anyone know the purpose of the water port circled in the picture? Extremely hot water comes out of this while the engine is...
Jul 22, 2025
ESGWheel
2005 Mercruiser MPI 5.0L misfiring(?) when in gear, idles fine
i forgot to mention that these types of dizzy caps usually have the cylinder no. stamped on it for each wire...
Jul 22, 2025
ESGWheel
reacted to
searay250's post
in the thread
with
Like
Ooops! Yes, good catch... I meant: 1) I feel like I have very fast consistent spark off the coil.... 2) Yeah when I sometimes DO get...
Jul 22, 2025
C
How to restore this 1961 hull?
When I had my '62 Crestliner with its rotten coring, the bow would make a small left or right turn, when hitting a wave. I replaced...
Jul 22, 2025
