V
vidaliaman
posted the thread
1971 25 hp evinrude outboard issue,
in
Johnson & Evinrude Outboards
1971 25 hp evinrude outboard issue, idles good but sneezes under a load, compression #1 84 #2 90, seems low, what do ya think? thanks dave
Jul 23, 2025
replied to the thread
4.3gxi bad temp sensor?
all readings need to be engine running. very few are KOEO
Jul 23, 2025
redneck joe
Random
Jul 23, 2025
pvanv
90hp Nissan outboard no spark on all 3 cylinders
You likely cooked the ECU.
Jul 23, 2025
redneck joe
Starting a 1974 Tri-Hull Restoration, it's a Stryker Mark IV model. Need help with any information or an owners manual.
The livewell must have more than one hole, two minimum but that center hole is too high up.
Jul 23, 2025
M
MikeSchinlaub
Some pics of the actual rear of the boat would help. Edit: The rear pic was dark and I missed it at first, just saw the interior...
Jul 23, 2025
redneck joe
Just looked more closely, not sure on your set up.
Jul 23, 2025
redneck joe
And. Just went thru the livewell thing. One is fill, one is drain, one is overflow. Then for the plug.
Jul 23, 2025
P
Pvaughan23
I know the four smaller holes are the mounts, the two at the bottom, one is for the Live-well and the other for the drain plug. Just not...
Jul 23, 2025
redneck joe
Holes for motor into think we're standardized by them if you go with an age appropriate motor. Bilge typically runs out the side at...
Jul 23, 2025
P
Pvaughan23
Jul 23, 2025
P
Pvaughan23
Does anyone know how to hook up an outboard through the Transom, like what holes are for what, where I can put my bilge pump outlet...
Jul 23, 2025
B
boscoe99
Merc 115 4 strokes 2001 ECU/fuel pump problem
Of course it is possible to power the fuel injectors (and other components) that normally get their power via the ECU. Using a simple...
Jul 23, 2025
Rasdiir
reacted to
Moserkr's post
in the thread
198x SS-150 rebuild
with
Like
Air or electric stapler is worth every penny!! I went air. Whats next on the list?? Build starts moving fast when the floors go in.
Jul 23, 2025
Rasdiir
198x SS-150 rebuild
Currently on vacation visiting family, but I'll still have a week off work when I return, so the foam and floor will be installed, I...
Jul 23, 2025
