T
tmorriss
replied to the thread
question on Yamaha ELG 40 carb rebuild
Thx. And yes, there is plug and it's there. Thank you again for the confirmations on this.
Wednesday at 12:33 PM
H
happychapboater
4.3gxi bad temp sensor?
It’ll be a couple days until I can test that when it’s finished getting painted.
Scott06
I have to do a gimbal bearing and bellows etc, I have a question regarding the shift cable. Merc A1 G1 3.0
you have to remove the cable to get the outer sheath off anyways. it gets removed out the bellhousing end. I usually tie a weedwacker...
Wednesday at 12:29 PM
FLATHEAD
reacted to
Scott Danforth's post
in the thread
Jimmys boat
with
Like
its just one of many of Jimmys fleet of boats. he also had a Westport that was being serviced down at Rybovich, and about 5 in the...
Wednesday at 12:27 PM
Scratch that no need to remove Detach, loosed shift cable bellows and pull it out some. Might attach a string to end in case it's...
Scott06
Throttle movement but no increase in engine rpms
Either damaged or the aluminum prop didn’t have as much cup or bite I have found that the aluminum 4 blades do not have the grip that a...
Wednesday at 12:25 PM
bigblocksarefun
reacted to
redneck joe's post
in the thread
Random
with
Like
Wednesday at 12:19 PM
bigblocksarefun
reacted to
Grub54891's post
in the thread
Ozzy Osbourne
with
Like
https://www.yahoo.com/entertainment/articles/ozzy-osbourne-black-sabbath-frontman-181737802.html
Wednesday at 12:18 PM
swift1
VP SX drive low oil but no sign of leak
No sheen. Just added another half litre and it's now reading on the dipstick. So about 2.6 l altogether to fill it, not 2.1. I'll let...
Wednesday at 12:09 PM
jimmbo
Less than full Inches by OMC for years.
Wednesday at 12:04 PM
Stinnett21
Kicker motor vs towing
Good catch. Yes I should have used "trailering" instead of "towing" in my original post. Panther does say "trailering".
Wednesday at 12:00 PM
Not everyone knows or even does that, also never heard of anything other than solid numbers for pitch
Wednesday at 11:59 AM
Yes and No Yes, disconnect then loosen 2 screws on end of wire anchor then remove plastic guide
Wednesday at 11:56 AM
Volvo penta trim relay issue
most likely you will need to cut the harness back and re-terminate. easy to do with the correct terminals. to pull the terminals out...
Wednesday at 11:55 AM
jimmbo
Here is what he wrote "18x14.5 4 blade aluminium to an 18 x 15.25 4 blade stainless" Diameter is usually placed before Pitch
Wednesday at 11:54 AM
