replied to the thread
2016 Mercruiser 6.2L ECT DTS Axius Cooling System Issue
Ted, drink one or two for us......
Wednesday at 1:38 PM
Throttle movement but no increase in engine rpms
15.5" is largest that fits on an alpha
Wednesday at 1:37 PM
1985 Century Mustang
reacted to
alldodge's post
in the thread
I have to do a gimbal bearing and bellows etc, I have a question regarding the shift cable. Merc A1 G1 3.0
with
Like
Yes and No Yes, disconnect then loosen 2 screws on end of wire anchor then remove plastic guide
Wednesday at 1:23 PM
reacted to
alldodge's post
in the thread
with
Like
Scratch that no need to remove Detach, loosed shift cable bellows and pull it out some. Might attach a string to end in case it's...
reacted to
Scott06's post
in the thread
with
Like
you have to remove the cable to get the outer sheath off anyways. it gets removed out the bellhousing end. I usually tie a weedwacker...
I stand corrected, old medium and small outboards used less than inch pitch and currently high end Rev4 and Enertia Eco XP using special...
Wednesday at 1:21 PM
FLATHEAD
Great loop speed record attempt
Definitely some kind of hiccup in Erie for a bit there.
tpenfield
reacted to
Fun Times's post
in the thread
with
Like
Nice Job Ted and thanks again for taking us all along for the ride too. 🚤🛥️🚤🛳️⛴️ And glad you got things "cooled down" just in time for...
Wednesday at 1:12 PM
Fun Times
Wednesday at 12:56 PM
Fun Times
reacted to
tpenfield's post
in the thread
with
Love
Here are my recordings from this morning . . . Since I did the Port engine first yesterday, I started with the Starboard engine today...
Wednesday at 12:48 PM
Scott06
the revolution 4 xp is available in some 1/2" pitch increments , I believe also the ventera has some 1/2" increments . These are also...
Wednesday at 12:46 PM
Lou C
reacted to
tpenfield's post
in the thread
with
Like
Wednesday at 12:45 PM
Fun Times
reacted to
tpenfield's post
in the thread
with
Love
I could temperature probe it fairly easily . . . not sure about measuring the flow. In other news . . . I drained, neutralized, and...
Wednesday at 12:41 PM
Fun Times
reacted to
tpenfield's post
in the thread
with
Love
There is not much information about the 'strainer' (8M0095457) in the cooling system. So, as part of my checking of the cooling system...
C
cyclops222
Check the butterfly shaft for GROOVES cut into it. Or wear grooves by the shaft into the support pieces.
Wednesday at 12:37 PM
