replied to the thread
On crank no fuel to throttle body mercruiser 305 EFI
Welcome Most likely we will need your motor serial number, but until then Looks like TBV distributor So it will not start on it's own...
Wednesday at 4:25 PM
C
cyclops222
Kicker motor vs towing
My super old Analog Cell Phone had many times the range of digitals. Police and Rescue people wanted those lone range Analogs. I had to...
Wednesday at 4:22 PM
A
Alfgeiger1
posted the thread
in
Mercury MerCruiser Sterndrives & Engines
Sea Ray 2001 SD240 with 5.0L EFI GM 305 motor, on crank do not get fuel to throttle body from the injectors See no spray, hear the...
Wednesday at 4:05 PM
B
beruken
salt water in single cylinder
So quick update. Engine started right up, a little rough while on choke as usual. Once it kicked off it smoothed out and sounded pretty...
Wednesday at 3:54 PM
1992 Nissan NS90A alarm at low speed, Dies above 3/4 Throttle
Welcome Never worked on a Nissan but your getting an alarm and then the motor starts to die. Need to do some testing Did find that the...
Wednesday at 3:31 PM
A
airshot
No clue, just a Samsung phone thru TracFone at walmart. Never been out on the big lake when I haven't had service. Others in my boat...
Wednesday at 3:12 PM
P
Pmt133
reacted to
MikeSchinlaub's post
in the thread
Boats from work.
with
Like
Yesterday, thinking I had all the bodywork done, I found a nice long crack. So I geound and glassed it yesterday, and today I sprayed...
Wednesday at 3:07 PM
reacted to
in the thread
Boats from work.
with
Like
Wednesday at 2:52 PM
M
MikeSchinlaub
Boats from work.
Wednesday at 2:41 PM
F
fleetwinner
reacted to
airshot's post
in the thread
1955 Evinrude Fleetwin 7.5 Carburetor
with
Like
Buy a real carb rebuild kit, with all new gaskets, needle and seats, and it will also give all settings to reassemble to factory specs...
Merc 115 4 strokes 2001 ECU/fuel pump problem
Have you tried replacing the relay, check clean and tighten contacts on relay? Merc ECM's apply a ground to one side of the relay coil...
Wednesday at 2:25 PM
Scott06
Throttle movement but no increase in engine rpms
16" is the diameter limit for alphas
Wednesday at 2:00 PM
Grub54891
reacted to
FLATHEAD's post
in the thread
Ozzy Osbourne
with
Like
I think just about everyone back in the day owned the Paranoid album.
Wednesday at 1:55 PM
tpenfield
reacted to
Scott Danforth's post
in the thread
2016 Mercruiser 6.2L ECT DTS Axius Cooling System Issue
with
Like
Ted, drink one or two for us......
Wednesday at 1:41 PM
tpenfield
Thanks everyone 🙏 . . . I appreciate the guidance and moral support. I am not sure what the temperature is supposed to be. I looked...
Wednesday at 1:40 PM
