A
airshot
reacted to
racerone's post
in the thread
How to restore this 1961 hull?
with
Like
I have used 1-1/2 plastic pipe cut in half.-----Used to make ribs / stringers.-----The fiberglass is laid over the pipe to give it the...
Wednesday at 5:47 PM
M
Mc Tool
replied to the thread
salt water in single cylinder
sounds like a blown head gasket .Symptoms being , water in only one pot , water in oil and no compression in that pot . Maybe head...
A
Alfgeiger1
On crank no fuel to throttle body mercruiser 305 EFI
Thanks for this, I do use them for parts, when you say TBV Distributor do you think it is the entire distributor, could it just be a bad...
Wednesday at 5:46 PM
Scott06
I have to do a gimbal bearing and bellows etc, I have a question regarding the shift cable. Merc A1 G1 3.0
Clicked the wrong one, didn’t think it was a hanging offense …sorry
Wednesday at 5:44 PM
And just why are you responding to me? Why not respond to the OP He asked?
Wednesday at 5:39 PM
M
Mc Tool
Throttle movement but no increase in engine rpms
yeah but :D, its kinda obvious that the OP got it arse about face ( which is cool , I knew what you meant :) ).... I mean someone...
Wednesday at 5:33 PM
Scott06
I didn’t have to cut my cable , just took the end off the shift plate end pulled inner completely out the bellhousing with weed walker...
Wednesday at 5:31 PM
This works but assumes your replacing the lower cable so you have one to cut
Wednesday at 5:22 PM
Your motor breakdown
Wednesday at 5:20 PM
1985 Century Mustang
Will fishing line work?
Wednesday at 5:17 PM
M
Mc Tool
reacted to
alldodge's post
in the thread
with
Like
That's the diameter, pitch is 18
Wednesday at 5:15 PM
M
Mc Tool
reacted to
jimmbo's post
in the thread
with
Like
Airflow Sensor? The Air Valve over the Secondaries, is opened by the Pressure Differential that is between above and below it. It is...
Wednesday at 5:12 PM
redneck joe
Great loop speed record attempt
Didn't know there wasn't a way to shortcut the UP
Wednesday at 5:08 PM
A
Alfgeiger1
Yes it starts with starter fluid. Will check the voltages, thanks
Wednesday at 4:40 PM
A
Alfgeiger1
0M086516
Wednesday at 4:37 PM
