R
RMassa187
replied to the thread
Alpha Gen 2 Stalls Going to Neutral (Shift Cable Replaced)
The shift plate components are free and move perfectly. To test this I took the cables off and verified nothing is binding. I also...
Wednesday at 7:34 PM
C
cyclops222
reacted to
JimS123's post
in the thread
Kicker motor vs towing
with
Like
I have a Panther mount on 2 of my boats with kickers. These mounts are awesomely sturdy, and I use multiple boats thru bolted with a SS...
Wednesday at 7:33 PM
R
RMassa187
I realize the quick shifting part because of the cutout. I am shifting briskly due to that.
Wednesday at 7:32 PM
P
Pmt133
reacted to
MikeSchinlaub's post
in the thread
Boats from work.
with
Like
It's just bondo and duraglas. Same stuff for autobody work. We've been using USC stuff for a while.
Wednesday at 7:15 PM
M
MikeSchinlaub
Boats from work.
Wednesday at 7:08 PM
D
Drivewayboater2
Boats from work.
Curious. What’s your go to fairing product for below the waterline?
Wednesday at 6:48 PM
D
Drivewayboater2
reacted to
in the thread
Boats from work.
with
Like
Yesterday, thinking I had all the bodywork done, I found a nice long crack. So I geound and glassed it yesterday, and today I sprayed...
Wednesday at 6:43 PM
C
cyclops222
reacted to
in the thread
Starting a 1974 Tri-Hull Restoration, it's a Stryker Mark IV model. Need help with any information or an owners manual.
with
Like
How long ago were the stringers and transom done? If the floor is rotten, they most likely they need redone too. You're in for a lot of...
Wednesday at 6:35 PM
C
captainnate
1972 Starcraft Nova
I was testing the fit before I drill holes in the new dash plywood. I was hoping I could simply reattach the windshield without...
Wednesday at 6:33 PM
C
captainnate
1972 Starcraft Nova
Wednesday at 6:29 PM
B
boscoe99
Merc 115 4 strokes 2001 ECU/fuel pump problem
OP's motor is of Yamaha origin I believe. Power comes from the ECU for the injectors and a couple of other components. Or it is supposed...
Wednesday at 6:26 PM
A
Alfgeiger1
On crank no fuel to throttle body mercruiser 305 EFI
When you say module is that the ECM Engine Control Module?
Wednesday at 6:13 PM
A
Alfgeiger1
Wednesday at 6:12 PM
JimS123
Wednesday at 5:54 PM
It's almost never the coil Most cases it's a bad connection or the old style module. The old modules had grounding problems, so Merc...
Wednesday at 5:50 PM
