tg3690
reacted to
redneck joe's post
in the thread
Random
with
Like
Wednesday at 11:27 PM
tg3690
posted the thread
Electronic distributor made a buzzing sound
in
Force & Chrysler Outboards
Was going to start my motor on muffs with the cowling off......turned the key on and pushed in for the choke. Then I noticed a faint...
Wednesday at 11:25 PM
jimmbo
replied to the thread
Throttle movement but no increase in engine rpms
OMC did that with their biggest Outboards, the V4s up till 1969
Wednesday at 9:52 PM
B
Bluemoon99
posted the thread
thunderbolt ignition blows fuse after start
in
Mercury MerCruiser Sterndrives & Engines
98 Bayliner 5.0 Left ignition key on for days Recharge battery Blows 15 ignition fuse after starter disengages . Any suggestions?
Wednesday at 9:42 PM
6
63a16p
08 350Mag/B3 eng low voltage
Did some more diagnostics today. Removed anti-siphon valve to check if it is sticking. Seems to be working correctly - opens with...
Wednesday at 8:55 PM
K
kadehamilton
75 hp Evinrude issues
Thank you for your reply, and sorry it took me so long to get back on here. I'm waiting for my manual to come in to finish working in...
Wednesday at 8:43 PM
K
kadehamilton
reacted to
lent0n's post
in the thread
with
Like
As far as power trim, racerone is right, it's either mounted on your engine or they've stashed it somewhere on board. I remounted a 79...
Wednesday at 8:41 PM
A
airshot
Problems starting after fuel filter/water separator change
Is there spark when cranking ?
Wednesday at 8:29 PM
C
cyclops222
reacted to
Mc Tool's post
in the thread
salt water in single cylinder
with
Like
sounds like a blown head gasket .Symptoms being , water in only one pot , water in oil and no compression in that pot . Maybe head...
Wednesday at 8:17 PM
C
cyclops222
reacted to
Mc Tool's post
in the thread
Kicker motor vs towing
with
Like
Yeah ideally a pair of motors makes good sense ,specially if your going a good distance. I am often surprised ( well not any more ) at...
Wednesday at 8:01 PM
H
helix757
posted the thread
in
I recently changed the fuel filter/water separator on my “new to me” boat. I filled the new filter with fresh gas before installing. I...
Wednesday at 7:58 PM
C
cyclops222
On crank no fuel to throttle body mercruiser 305 EFI
Many car and some EFI controlled engines have a very short ....Purging Period .....During the instant the starter is energized. About...
Wednesday at 7:48 PM
M
MikeSchinlaub
Boats from work.
Remember, it's just to fill small imperfections. You want like 90% glass. You have a project that you need help with?
Wednesday at 7:42 PM
D
Drivewayboater2
Boats from work.
Okay thanks
Wednesday at 7:37 PM
R
RMassa187
Alpha Gen 2 Stalls Going to Neutral (Shift Cable Replaced)
Unfortunately boat is in the water. Lower shift cable feels smooth and easy to push/pull.
Wednesday at 7:35 PM
