BWR1953
reacted to
IslandExplorer's post
in the thread
1974 Chieftain 25 "Adventurer" Restoration
with
Like
Serious delay- had to cut roof out bc of defective plywood issue. Prob better I'm replacing this particular piece with marine ply...
Thursday at 9:53 AM
U
UtTex
posted the thread
Stringer boot recommendations?
in
OMC I/O & Inboard Engines & Outdrives
I'm fixing up my 79 Starcraft Chieftan and I'm at the point of installing a new rubber boot for the OMC Stringer outdrive...
Thursday at 9:53 AM
replied to the thread
simpli safe
ADT is not as good as it once was. following along out of curiosity. my first reaction is to use this:
Thursday at 8:54 AM
B
Bluemoon99
thunderbolt ignition blows fuse after start
The coil was shorted and replaced. So now it starts for a few seconds , soon as starter motor disengages the fuse will blow. Have...
Thursday at 8:45 AM
A
Alfgeiger1
On crank no fuel to throttle body mercruiser 305 EFI
If my engine s/n is 0M086516 could you recc the module part that would fit? Thanks
Thursday at 8:39 AM
MNhunter1
1972 Starcraft Nova
Windshield replacement seal was from Taylor Made Systems, profile 8288020. I purchased 8' at $2.27/ft + shipping and handling...but that...
Thursday at 8:33 AM
T
tphoyt
simpli safe
I use them for freeze protection and have not had any trouble. So far they have been a good product. Wish I could offer more info on the...
Thursday at 8:33 AM
Problems starting after fuel filter/water separator change
Use a voltmeter and see if 12V is at the coil pink/white wire with key ON
Thursday at 8:23 AM
C
cyclops222
reacted to
redneck joe's post
in the thread
simpli safe
with
Like
thanks but lets keep this on on topic you you would please.
Thursday at 8:21 AM
redneck joe
simpli safe
Thursday at 8:18 AM
IslandExplorer
Thursday at 8:01 AM
H
helix757
Are you referring to the red switch at the controller? If so, yes I confirmed.
Thursday at 7:57 AM
reacted to
BRICH1260's post
in the thread
VP SX drive low oil but no sign of leak
with
Like
Always fill until it flows from the upper side vent screw hole. It is possible that you could have a driveshaft seal bad and that the...
Thursday at 7:42 AM
IslandExplorer
Transom replacement 1975 18' SS
Splashwell cracks can form from the transom being too flexible/soft. Once replaced it is still a reinforcement but not required usually...
Thursday at 7:39 AM
IslandExplorer
reacted to
MNhunter1's post
in the thread
with
Like
Yep, the rivets sticky should give you pretty much everything you need. 3/16's primarily, with 5/32's used on stuff like the gunnel...
Thursday at 7:32 AM
