replied to the thread
Volvo penta trim relay issue
google VF4 relay socket or VF4 relay receptacle.. the socket should be about $1.50 each and the terminals a few cents from Mouser /...
Thursday at 11:15 AM
How to restore this 1961 hull?
my first hydrostream was a balsa core......that was rotten
Thursday at 11:10 AM
C
Rotary steering cable
I am trying to get the wheel straight on my speedboat. I need to look good for the audience, however, with the NFB system it is hard.
Thursday at 11:07 AM
C
1984 115hp TOP Switch Box Wiring
It is hard to tell from a picture if the ground is good. Some general stuff. All those questions ask if the grounds are good. If you...
Thursday at 11:06 AM
C
To be accurate, the balsa coring in my '62 Crestliner went from chine to chine, not to the gunwales. The sides were solid 3/16" or...
Thursday at 11:01 AM
jimmbo
I gave up caring about where the Wheel pointed, back in about 1972, when I was 12
Thursday at 10:51 AM
C
thunderbolt ignition blows fuse after start
Also check the accessory wire from the ign switch, rubbed bare somewhere and shorting to ground. It should be purple.
Thursday at 10:50 AM
C
The steering wheel position is one of ascetics. On a destroyer wheel or other steering wheel that does not have a "straight" position...
Thursday at 10:48 AM
U
utfyrfytr
posted the thread
in
Steering and Controls
I removed the rotary steering cable at the helm on my 1997 Crestliner Sport fish. When I reinstall it is there a certain position that...
Thursday at 10:30 AM
Fun Times
The fuse near the ignition key switch? should be a 20-amp fuse. Possibly something got hot and created an internal short...Key switch...
Thursday at 10:28 AM
H
helix757
Problems starting after fuel filter/water separator change
I will check this today -- ty!
Thursday at 10:24 AM
tg3690
Electronic distributor made a buzzing sound
Nordin and jerry, thanks for replying. I wanted to run this by yall before I started making calls. I have talked to both Franz and...
Thursday at 10:16 AM
BWR1953
simpli safe
Whatever you install, make sure that it has virtually instant access to what the cameras are seeing or what the alarms are sounding...
Thursday at 10:13 AM
S
sdreinell
copy that, thanks. I'll see if I can get them to release with a small screwdriver or something. Looks like I can also buy the whole...
Thursday at 10:08 AM
IslandExplorer
1974 Chieftain 25 "Adventurer" Restoration
5/8 marine ply roof replacement bolted down last night. Think I'm going to keep the cabinets out, at least for now. It's so roomy...
Thursday at 10:00 AM
