C
cyclops222
replied to the thread
1995 2 stroke, 0G310728, Bogging full throttle
Are both pluge correct number ? Good blue sparks ? Replace both spark plugs ?
Aug 16, 2025
ezbtr
posted the thread
A few questions on a new to me 2020 Mustang GT
in
Non-Boating Technical Topics
10 speed automatic transmission, just got it, one owner, 30,000 miles, full warranty, staggered and dropped with Carol Shelby wheels and...
Aug 16, 2025
N
Nordin
New to me 18 hp Evinrude.
Bman2895 have you pull the flywheel and check the points, cleaned them and set the gap and looked at the coils?
Aug 16, 2025
C
cyclops222
Any new correct sparkplugs ? Swap H V cables to spark plugs when problem occurs ? Does the bad cylinder have a slightly loose connection...
Aug 16, 2025
F
Flashcardsgo
yamaha 3.0 l4 blew head gasket help!
I really appreciate all you guys support being an owner of not one but 2 30-50 year old boats is sometimes a challenge and frustrating...
Aug 16, 2025
aspeck
Let's talk skill...
Just because it is a cheap Bayliner doesn't mean it can't look good! I think Bayliners in general put out some really sweet looking...
Aug 16, 2025
T
twalt42
reacted to
Scott Danforth's post
in the thread
New sea pump front seal walking out. Causes? Fixes?
with
Like
I would pull the seal, get a new one and install with a bit of permatex around the outer edge.
Aug 16, 2025
aspeck
reacted to
redneck joe's post
in the thread
Random
with
Like
Aug 16, 2025
C
cyclops222
Harness to lift 9.8 4 stroke off and on transom while in yard
Need a lot more description of your cruiser and Davits that raise and lower a stern mounted tender / lifeboat / inflatable. What do...
Aug 16, 2025
F
Flashcardsgo
reacted to
Mc Tool's post
in the thread
with
Like
Its probly got the temp stamped on it somewhere and as long as you get one the same shape , auto parts store :)
Aug 16, 2025
F
Flashcardsgo
reacted to
Mc Tool's post
in the thread
with
Like
Well there you go . I think you need to get another means of measuring engine to verify temp gauge is working and to test engine temp
Aug 16, 2025
F
Flashcardsgo
reacted to
Grub54891's post
in the thread
with
Like
I adapt the hose for my vacuum bleeder to fit the outside of the tube, mine fits tight to the tube so I don’t need to clamp it. The tube...
Aug 16, 2025
F
Flashcardsgo
reacted to
Grub54891's post
in the thread
with
Like
I get a bit of milky in mine, mostly when not running it hard enough on my 350 acre lake. If I take it out on lake Superior I can get...
Aug 16, 2025
F
Flashcardsgo
reacted to
airshot's post
in the thread
with
Like
Re check your compression numbers, new engines are only 150 psi, might be a bad gage.
Aug 16, 2025
C
cyclops222
reacted to
Mc Tool's post
in the thread
Tell tale not peeing
with
Like
Often the hose supplying the muffs doesnt have enough oomph to prime the pump . When you dunk it in the water at the ramp the water...
Aug 16, 2025
