J
jlh3rd
replied to the thread
Is A I a totally unreliable function ?
not only testing, La. allowed polygraphs...just to get a job in a lumber yard. If you wanted a job loading bags at Delta, you had better...
Aug 17, 2025
nola mike
2005 4.3 liter Mercruiser ignition trouble
so now you need to find out where you're losing your ignition voltage. you get 12v at the coil with ignition on? you can check...
Aug 17, 2025
D
daf64
posted the thread
Water leaking
in
Johnson & Evinrude Outboards
Hello fellow boaters. I have a johnson 60 hp outboard. Year 2000 20" shaft. I had to replace the water pump an thrrmostate, now I have a...
Aug 17, 2025
jimmbo
99 Volvo 5.0GL
https://www.marineengine.com/newparts/part_search.php?part_num=3858261
Aug 17, 2025
FLATHEAD
Epic launch
Years ago on a cold October day my wife and I took a ride to the lake. We saw what looked like divers at the ramp. We drove over to...
Aug 17, 2025
D
DeepCMark58A
reacted to
redneck joe's post
in the thread
Had a heck of a day
with
Like
So awesome
Aug 17, 2025
G
gmasters
reacted to
ESGWheel's post
in the thread
PERKO Vented Gas Caps – how they work and a couple of tips
with
Like
This is about the gas cap for the Perko Combination Fill and Vent Necks. Like in Picture 1. This is not about the newer EPA compliant...
Aug 17, 2025
G
gmasters
Missing info I was looking for but best info I have found so far, thanks- I am troubleshooting venting, there appears to be a Surge...
Aug 17, 2025
N
N2outboards
Adjustment to rear transom roller arms
Thank you sirs
Aug 17, 2025
reacted to
dingbat's post
in the thread
A few questions on a new to me 2020 Mustang GT
with
Like
One of my vehicles comes standard with 18” wheels but jumps to 20” in top trim package. My door sticker (20”) says 34 psi. Owners...
Aug 17, 2025
B
Bhuie
99 Volvo 5.0GL
So I’ve replaced fuel filter, checked all the fuel lines from the bottom screen to anti siphon valve to fuel pump and fuel pump to carb...
Aug 17, 2025
Lou C
Volvo Penta stiff steering
You basically want to narrow down the cause by a process of elimination. If you disconnect the steering cable at the steering arm and...
Aug 17, 2025
S
sinkhole
Retaining ring on1975? Johnson
No info. available OMC stoped making in 1973 i think. Made in Peterborough Canada same basically as 25 hp.
Aug 17, 2025
P
peters715
posted the thread
No Trailer and Trim Up
in
Mercury MerCruiser Sterndrives & Engines
This is a common issue, however my gear is uncommon and the recommendations don't apply. 69 Star Chief with Mercruiser 120. Unlike...
Aug 17, 2025
S
sinkhole
Aug 17, 2025
