jimmbo
replied to the thread
Reduced speed under load
That Mixture Adjuster, only adjusts the Idle Mixture. As other have said, it appears to be a Case of Dirty Carb(s), however. Is the...
Aug 18, 2025
guy48065
What is this indicator? (2000 Bayliner)
While messing with the switch a long beep sounded--like an alarm. I'm not sure if I reset the zero depth or maybe it alarms at a minimum...
Aug 17, 2025
M
mike97520
posted the thread
Console Wiring 1996 Sea Swirl Bowrider 201 Limited Edition
in
Seaswirl Boats
Hello, I am trying to uncover some gremlins behind the steering column of my 1996 Seaswirl 201 Bowrider Limited Edition. I realize there...
Aug 17, 2025
ingham01952
posted the thread
Port motor out!
in
Volvo Penta I/O & Inboard Gas Engines & Outdrives
2004 Vista 288 with dual 305GXI-E 3869255 4012123147 Looking for some advice on an issue with my port motor today. Both tanks were...
Aug 17, 2025
nola mike
Fuel Sender Leak
Are you able to rotate the sender and screw into fresh plastic? Try sharing some pics on google photo or icloud or whatever
Aug 17, 2025
nola mike
Boat opinions
Don't need it for the kicker
Aug 17, 2025
scorpio65
posted the thread
1976 115hp low to no spark
in
Johnson & Evinrude Outboards
Hi my outboard ran great last weekend but when I tried to start this Friday no spark or very very small on all 4. Battery full and was...
Aug 17, 2025
nola mike
are there boat "salvage yards" anywhere in the U.S.?
There was one across the river from me, but looks like they closed. They were expensive anyway. Check out larger independent...
Aug 17, 2025
A
airshot
Best to get a factory rebuild kit so you will have new gaskets, new needle and seat as well as instructions to set it up for your motor...
Aug 17, 2025
A
airshot
reacted to
tphoyt's post
in the thread
Bait and Livewell
with
Like
I have been icing my fish my whole life. That’s just way I learned and have never thought of any other way. The only time we would use a...
Aug 17, 2025
D
Donald0039
Sqeeking sound from belt after impeller inspection
There is a shaft seal in the raw water pump. The rubber seal can get hard & brittle. If your raw water pump dripped a little I would...
Aug 17, 2025
nola mike
Pre Alpha Mercruiser lower shift shaft removal?
Why are you trying to remove it? If you do then you'll need disassembly. If you're just trying to replace the seal, then like BT says...
Aug 17, 2025
nola mike
1986 Mercruiser 170 running issue
Yeah, sounds like it's flooding though certainly other possibilities. Does it happen if you have it sitting at a fast (~1500 rpm ) idle...
Aug 17, 2025
O
oldfarmall
Hi Bt, thanks for the reply. I am trying to remove the splined shift shaft in the lower unit, it should come out the top of the lower...
Aug 17, 2025
D
Donald0039
2006 volvo penta 5.7 rebuild help
So what happened to the engine. It ingested water and rusted a few valves? Have you considered just pulling the heads?
Aug 17, 2025
