C
carlos515
replied to the thread
Changing colour of gelcoat question
Yes, those are the ribs I was referring to.
Aug 17, 2025
M
MikeSchinlaub
In pictures on the previous page, I can see what look like small boards glassed in place and running sideways between the stringer and...
Aug 17, 2025
B
Bellman73
posted the thread
1986 Mercruiser 170 running issue
in
Mercury MerCruiser Sterndrives & Engines
Hello all! new to the forum and have read most of the issues I can find with the Merc 170 inboard. Mine is a touch different as it...
Aug 17, 2025
dingbat
2003 YAMAHA 225HP 4S
https://www.boatus.com/expert-advice/expert-advice-archive/2013/july/yamaha-f225-corrosion-complaints
Aug 17, 2025
nola mike
2005 4.3 liter Mercruiser ignition trouble
Voltage drop test is measuring the voltage on either side of a connection when it's under load. With your meter on DCV, you probe each...
Aug 17, 2025
C
carlos515
I have 6x18" long by 2" high ribs on both sides of my keel. They do not join to the stringer. The wood has long since rotted away...
Aug 17, 2025
are there boat "salvage yards" anywhere in the U.S.?
Dons Salvage and Green Bay propeller are two I have been to
Aug 17, 2025
69' Whaler Nauset
Dry weight of your boat ( no rigging or motor) is 510#
Aug 17, 2025
M
mrschwarz
Boat opinions
I wasn't planning to get one for the kicker. Make sense?
Aug 17, 2025
Bt Doctur
Pre Alpha Mercruiser lower shift shaft removal?
If you mean the carrier the shift shaft comes out the top. you simply unscrew it and slide it off the shaft
Aug 17, 2025
FreeBeeTony
posted the thread
in
Yamaha & Suzuki Outboards
Considering a boat with a pair of subject engines. Ad says 900HRs. Any particular issues with these years? Not familiar with these at all.
Aug 17, 2025
O
oldfarmall
posted the thread
in
Hello- I have a pre alpha Mercruiser stern drive unit on a 1974 Glastron boat with a 140hp inboard. I am going through the lower unit...
Aug 17, 2025
P
Pmt133
Boat opinions
I prefer fixed mount VHF... no possible way of forgetting it at home or having a dead battery. And you can mount the antenna in a more...
Aug 17, 2025
P
Pmt133
You should have 12v at the starter. Possibly a fusable link there then that ties up to the circuit breaker as a red/purple then goes to...
Aug 17, 2025
R
robertw007
69' Whaler Nauset
I weighed my boat yesterday. Total was 740lb. According to what I could find online, dry weight says it's supposed to be ~826 lb. So I'm...
Aug 17, 2025
