redneck joe
replied to the thread
69' Whaler Nauset
AI Overview The 1969 Boston Whaler Nauset 16 bare hull weight is approximately 500 to 510 lbs. This is a standard factory...
Aug 18, 2025
redneck joe
69' Whaler Nauset
Yeah do the old shcool img code
Aug 18, 2025
Bob_VT
reacted to
racerone's post
in the thread
1976 115hp low to no spark
with
Like
A 50 year old motor.----Some will argue.----Step #1 is a compression test.----Post the actual values here.----Then test charge coil and...
Aug 18, 2025
69' Whaler Nauset
Joe, was trying to hot-link over to a continuous wave forum. vs trying to cut-n-paste.
Aug 18, 2025
Y
YOBE
Main Jet size for carb 7043183?
Currently I have 2 jets of 0.049 inch. But without finding more details, the info I can find is that this is probably too low.
Aug 18, 2025
redneck joe
69' Whaler Nauset
See posts 7 and 9 https://forums.iboats.com/threads/file-uploads-no-good-again.779708/#post-5989400
Aug 18, 2025
Y
YOBE
posted the thread
in
Mercury MerCruiser Sterndrives & Engines
Hi, I have been reading the service manual quite in detail and states that for my setup: Mercruiser 165HP 6cyl 70's it should have the...
Aug 18, 2025
M
MikeSchinlaub
Changing colour of gelcoat question
I don't see why you couldn't do a stringer there instead. It's going to be pretty small though.
Aug 18, 2025
Y
YOBE
A-Mercruiser I-Drive Unit: pre-load required?
Thanks! This confirms what I expected. Certailly when I inspected the original washer there was also not marking of "NUT" on it. (but...
Aug 18, 2025
P
Pmt133
If you're talking about the nut on the end of the yoke for the input shaft in which the gear set under the top cap is affixed to, the...
Aug 18, 2025
69' Whaler Nauset
Trying to post screenshots of the hull weights
Aug 18, 2025
Y
YOBE
posted the thread
in
Hi, Serial nr engine: 4506302. The 165HP 6cyl in-line. Based on the service manual and checking the upper unit of the stern-drive I...
Aug 18, 2025
R
are there boat "salvage yards" anywhere in the U.S.?
E-bay is a great resource.----Looking for engine parts or actual boat parts.
Aug 18, 2025
R
Aug 18, 2025
redneck joe
Boat opinions
Horns are easy to install and id do fix radio if you have the space
Aug 18, 2025
