C
cyclops222
reacted to
Pmt133's post
in the thread
Boat opinions
with
Like
I prefer fixed mount VHF... no possible way of forgetting it at home or having a dead battery. And you can mount the antenna in a more...
Aug 18, 2025
reacted to
Jesse Walter's post
in the thread
Bravo 1 to Bravo 3 Conversion
with
Like
Finally took the boat out yesterday after the new exhaust manifolds. The Bravo 3 performed flawlessly! Much better performance than...
Aug 18, 2025
J
jlh3rd
replied to the thread
Boat opinions
I use the echomap 2 53. Operating on the upper chesapeake, it has come in really handy, especially for a new bay operator that I am.
Aug 18, 2025
Scott06
How did the WOT rpm land - are you good with props you have ?
Aug 18, 2025
J
Jesse Walter
Aug 18, 2025
rickasbury
Hot water heater
It looks like there link for pictures works? There was only one line to change out on the faucet and the pump so that should be good...
Aug 18, 2025
2005 4.3 liter Mercruiser ignition trouble
Pull the connector off and look at the pins, many times the pins become corroded This is where it's good to know actually which 4.3...
Aug 18, 2025
scorpio65
reacted to
racerone's post
in the thread
1976 115hp low to no spark
with
Like
A 50 year old motor.----Some will argue.----Step #1 is a compression test.----Post the actual values here.----Then test charge coil and...
Aug 18, 2025
dingbat
Fuel Sender Leak
Duplicate post
Aug 18, 2025
scorpio65
reacted to
Bob_VT's post
in the thread
with
Like
I too have strange gremlims that infected my personal boat/outboard. I did as stated above with ONE ADDITIONAL thing.......... Get a...
Aug 18, 2025
dingbat
Fuel Sender Leak
Easy fix with rivet nuts. Select the thickness range to match wall thickness of tank...
Aug 18, 2025
scorpio65
Compression I can do.
Aug 18, 2025
H
HiWard
Port motor out!
Here's what I would do (disclaimer; I'm not an expert): Can you hear the fuel pump priming when turning the key on (no start)? If yes...
Aug 18, 2025
scorpio65
Like I said the testing process in the manual had me confused. Where and how to test those? The boat is currently dead in the marina.
Aug 18, 2025
Bob_VT
Aug 18, 2025
