D
dscopes
replied to the thread
Struggling with shifter/throttle cable installation on Johnson 25 HP
Yes, I’m aware of that. I’m still faced with the challenges that I stated 👆🏻
Aug 18, 2025
Scott06
Main Jet size for carb 7043183?
Sometimes you see them in the carb tune up specs in the factory manual but a quick search I cant find it either... How do the plugs...
Aug 18, 2025
2006 volvo penta 5.7 rebuild help
at 700 hours, the motor is barely broken in. most marine motors will run 4000 hours plus with proper maintenance Motor wont run at 80...
Aug 18, 2025
R
If it is a single lever control , the shifter cable is the first one that moves.
Aug 18, 2025
C
cyclops222
Hot water heater
Does your closed cooling system HAVE ANTIFREEZE ADDED TO IT ? Or is it only a fresh water system ? Would tell you a lot about any leaks...
Aug 18, 2025
C
cyclops222
reacted to
Grub54891's post
in the thread
Hot water heater
with
Like
Yes, I've winterized lots of them over time, and added that valve. But if the heater is bypassed, there should be no water in the tank...
Aug 18, 2025
It's a Rochester carb jet number 1397-3827 but don't know the size...
Aug 18, 2025
R
Reduced speed under load
According to your model # it is a 1975 and no electric shift.----Do you agree?
Aug 18, 2025
C
cyclops222
reacted to
alldodge's post
in the thread
Hot water heater
with
Like
Many boats have winterization valves next to hot water tank. The valves are there so the tank can be bypassed which allows RV antifreeze...
Aug 18, 2025
Console Wiring 1996 Sea Swirl Bowrider 201 Limited Edition
gauge wiring should be part of the motor schematics in the motor manual. standard ABYC color scheme is in the electrical forum stickies.
Aug 18, 2025
D
dscopes
posted the thread
in
Johnson & Evinrude Outboards
Hello folks, I’m having a hard time installing the shifter and throttle cables on my 2002 Johnson 25 HP outboard. I have an...
Aug 18, 2025
P
Panda809
Hey everyone. Thank you for the information. I have not cleaned or rebuilt the carbs. I do have the service manual and parts catalog for...
Aug 18, 2025
I
Irelander
reacted to
crankbait cowboy's post
in the thread
1973 starcraft ss restore in progress
with
Like
Re: 1973 starcraft ss restore in progress so i got a little more done on the restore. that extra board on transom skin left a lot of...
Aug 18, 2025
Port motor out!
it would not turn over, or it would not fire. Two completely different issues. since you typed it would not turn over.....check the...
Aug 18, 2025
C
cyclops222
Boat opinions
Nothing is more reliable than a plastic covered underwater terrain map. It works EVERY TIME. I do NOT play Russian Roulette by doing...
Aug 18, 2025
