R
replied to the thread
Reduced speed under load
I would say the motor is a 1975 model.-------A 1973 is listed as a 50373R-----A 1974 model is 50473M
Aug 18, 2025
J
Jesse Walter
Bravo 1 to Bravo 3 Conversion
I actually didn't hit WOT yesterday. I was just enjoying finally being out and we mostly cruised at 3-3300 RPM going about 30-33 mph on...
Aug 18, 2025
K
kenny nunez
A-Mercruiser I-Drive Unit: pre-load required?
The washer should be slightly ‘cupped”and you see where the nut contacted it so be sure to put some Loctite on the threads. The nut...
Aug 18, 2025
C
cyclops222
Console Wiring 1996 Sea Swirl Bowrider 201 Limited Edition
How old is this problem ? How long since you bought the boat ? How do you know that disconnecting the wire to the Kill Switch has not...
Aug 18, 2025
Main Jet size for carb 7043183?
I'm sure there is in paper somewhere. Could ask a place like Mike's Carbs and he may have the info
Aug 18, 2025
Y
YOBE
Mine are similar to this JET. So that would fit I guess. Just weird there is no info on what size the originals are.
Aug 18, 2025
K
kenny nunez
1986 Mercruiser 170 running issue
Try running the bilge blower, since a 470 is fresh water cooled it builds more heat under the cover. Also buy a new rotor for the...
Aug 18, 2025
Scott06
No Trailer and Trim Up
Do you have a wiring diagram for your set up? I know the earlier ones are a bit more complicated... If i recall you have the three...
Aug 18, 2025
C
cyclops222
You should be experiencing bits of old dried out gasoline varnish coming loose in the tiny passages of the carburetor. I normally just...
Aug 18, 2025
P
Panda809
I may be incorrect about the electric shift. But I can confirm that the motor model number is 50573R and the two manuals (service and...
Aug 18, 2025
C
cyclops222
are there boat "salvage yards" anywhere in the U.S.?
We have boat dumping areas in the farm lands. Some are large. Remove parts when bees are not active in colder weather.
Aug 18, 2025
sangerwaker
reacted to
DeepCMark58A's post
in the thread
Had a heck of a day
with
Like
Burned 50 gallons of boat gas yesterday the 3 person tube is destroyed but the boat did not miss a beat. I was a little concerned with...
Aug 18, 2025
C
cyclops222
1976 115hp low to no spark
Price out replacing that motor. Motor and all the new controls cost and labor.
Aug 18, 2025
C
carlos515
Changing colour of gelcoat question
Thank you, the stern ones are larger than the bow ones. I was just worried that the hull would be too stiff.
Aug 18, 2025
C
cyclops222
Do not ne surprised at the poor record of brand new motors. Some still waiting for replacement new parts. Very poor cast Aluminum...
Aug 18, 2025
