Scott06
replied to the thread
Bravo 1 to Bravo 3 Conversion
if 6 ppl plane out time was good you are probably in the ballpark. Will be lucky $$$ if you can run the same props.
Aug 18, 2025
Horigan
Oil Pressure Sender failure modes?
A pressure switch is very different than a pressure sensor/sender. A pressure sender has a strain gauge, piezo sensor, or some other...
Aug 18, 2025
C
cyclops222
Is A I a totally unreliable function ?
Latest A I problem from A I. US Government is complaining A I is using up loads of electric power all over the USA. Electric...
Aug 18, 2025
Scott06
Main Jet size for carb 7043183?
As Ad points out I have seen it for some carbs in the carb section of manual or some addendums, but not for anything that old. I think I...
Aug 18, 2025
jimmbo
Reduced speed under load
A 73 has an entirely different Gearcase than a 75. What is the Diameter of the Prop?
Aug 18, 2025
C
cyclops222
reacted to
jlh3rd's post
in the thread
with
Like
not only testing, La. allowed polygraphs...just to get a job in a lumber yard. If you wanted a job loading bags at Delta, you had better...
Aug 18, 2025
Grub54891
reacted to
Scott Danforth's post
in the thread
Port motor out!
with
Like
measure the fuel pressure. you may have a pump going out. (common issue)
Aug 18, 2025
Grub54891
Hot water heater
Do you actually have a coolant tank with antifreeze in it?
Aug 18, 2025
B
Bman2895
New to me 18 hp Evinrude.
Yeah I'm familiar with servicing these ignitions. (How to set points, install parts etc). Though when a spark appears good when tested...
Aug 18, 2025
you are being about 1000% generous. about 90 out of 100 questions are wrong, grabbing the recent social media answers (because its...
Aug 18, 2025
Grub54891
yamaha 3.0 l4 blew head gasket help!
I get the condensation up top at times. Good hard run takes care of it. On others I’ve worked on that got submerged we remove the oil...
Aug 18, 2025
Port motor out!
Aug 18, 2025
ingham01952
Port motor out!
It turns. It won’t actually start. update it is now 12 hours from the last time it ran and will not start at all. Starboard motor...
Aug 18, 2025
P
peters715
No Trailer and Trim Up
I do have a wiring diagram and some of it makes sense. I think the way it is supposed to work is Trim up uses the switch to stop trim...
Aug 18, 2025
kd4pbs
I hate to be the bearer of bad news, but if the oil you drained was milky, the oil you replaced will also become milky. You've got more...
Aug 18, 2025
