P
Panda809
replied to the thread
Reduced speed under load
Thank you for helping me sort through the “shift” topic. Do you have suggestions to order carb rebuild kits and any needed tools?
Aug 18, 2025
M
MBAKER
Swap mercruiser 5.0 for a 5.7
I did this a few years ago in a 2000 model but would expect it to go the same for you especially if you have the same intake setup. I...
Aug 18, 2025
R
Definitely ---NOT---electric shift.
Aug 18, 2025
scorpio65
1976 115hp low to no spark
I'll just replace with a cheap '80s 70-90hp. If need be.
Aug 18, 2025
2014 GMC Sierra AC
update from the camping trip in Tennessee. the AC worked flawlessly for about 80% of the trip up to Chattanooga. however the AC...
Aug 18, 2025
R
Water leaking
I doubt that a 2000 model uses an O-ring below the driveshaft splines.
Aug 18, 2025
jimmbo
The 1973 50hp, Electric Start, uses a Hydro-Mechanical Shift Gearcase
Aug 18, 2025
BWR1953
reacted to
IslandExplorer's post
in the thread
Is it only a matter of time for leaks?
with
Like
I'd agree with the Super Sport vote, amazingly versatile and convenient layout. That bow area is not to be underestimated! Motors-...
Aug 18, 2025
S
saltchuckmatt
Water leaking
It won't do pictures right now (technical issues) but you canale a video and post the link. Not that hard to do. O ring is to keep...
Aug 18, 2025
A
AussieB
Like I stated earlier, I'm just in the early stages of research so I'm not rushing out to buy a boat. All the ducks need to be in a row...
Aug 18, 2025
K
kenny nunez
Pre Alpha Mercruiser lower shift shaft removal?
Do not keep trying to pull the shaft out! There is a small clip and a washer under the bushing, if the clip should break it falls into...
Aug 18, 2025
J
jmanspin
posted the thread
20 DLX glove box
in
Sanger Boats
Searching for '96 20 DLX glove box w/lid (or just lid) or a compatible replacement. TIA
Aug 18, 2025
J
Jeff J
reacted to
Scott Danforth's post
in the thread
Port motor out!
with
Like
it would not turn over, or it would not fire. Two completely different issues. since you typed it would not turn over.....check the...
Aug 18, 2025
redneck joe
reacted to
in the thread
with
Like
Aug 18, 2025
P
Panda809
I really apologize. I just rechecked the model number and it is in fact 50373R. Again my apologies for the confusion. Thanks!
Aug 18, 2025
