dingbat
replied to the thread
Oil Pressure Sender failure modes?
Would require additional circuitry. Most work the same principal as a liquid level sending unit. Diaphragm driven wiper rubbing a...
Aug 18, 2025
A
airshot
are there boat "salvage yards" anywhere in the U.S.?
If still open, there is one in LaSalle Mich. Called Checkers. I know there are others, but have only used this one.
Aug 18, 2025
K
kenny nunez
The Boat Yard in Marrero,La. Across the river from New Orleans.
Aug 18, 2025
A
airshot
reacted to
racerone's post
in the thread
with
Like
E-bay is a great resource.----Looking for engine parts or actual boat parts.
Aug 18, 2025
Wave34
posted the thread
Engine overheats after water heater failure
in
Boat Topics and Questions (not engine topics)
The boat is a 2004 Chaparral Signature 5.7L MPI I don't know if it's related but it happened at the same time. The las week end, I was...
Aug 18, 2025
A
airshot
reacted to
jimmbo's post
in the thread
Reduced speed under load
with
Like
That Mixture Adjuster, only adjusts the Idle Mixture. As other have said, it appears to be a Case of Dirty Carb(s), however. Is the...
Aug 18, 2025
A
airshot
reacted to
AussieB's post
in the thread
Is it only a matter of time for leaks?
with
Like
Like I stated earlier, I'm just in the early stages of research so I'm not rushing out to buy a boat. All the ducks need to be in a row...
Aug 18, 2025
K
kenny nunez
Pre Alpha Mercruiser lower shift shaft removal?
Once the bushing is removed the shaft can be pulled out. If the shift shaft is stainless steel leave it and install the new bushing...
Aug 18, 2025
redneck joe
Couple other thoughts, high school girl mewn high school girl and boyfriends, open bow let's them have a cool place to be rather than...
Aug 18, 2025
nola mike
I am so underwater with easy projects I can't tell you. Busy hurricane-proofing today. I finally got the boat working well enough that I...
Aug 18, 2025
redneck joe
I have a center console so by default an open bow and since 99% of the time i launch by myself not having to navigate the bow and the...
Aug 18, 2025
S
Steven Leary
posted the thread
Looking for picture of exterior Transom wood plate for Alumcraft model E 12’ combination Row OB Motor boat.
in
Alumacraft Boats
Aug 18, 2025
redneck joe
Aug 18, 2025
R
factory kits.-----No special tools needed.
Aug 18, 2025
O
oldfarmall
Kenny- I already had the screw in bushing and seal removed, but it doesn't seem to lift out? I can see the washer and clip you are...
Aug 18, 2025
