Grub54891
reacted to
rickasbury's post
in the thread
Hot water heater
with
Like
Im closed cooling- raw water cools the heat exchanger. I have a separate pump just like a car for the coolant.
Aug 18, 2025
FreeBeeTony
replied to the thread
2003 YAMAHA 225HP 4S
Thanks for the response. Guess I should pass.....
Aug 18, 2025
rickasbury
Hot water heater
Aug 18, 2025
kd4pbs
1986 Mercruiser 170 running issue
Is this a new-to-you boat? Does this boat have an aftermarket Pertronix electronic ignition module? When it cuts off, look in the carb...
Aug 18, 2025
Z
zuchero
posted the thread
LOWER END OIL CHANGE
in
Mercury & Mariner Outboards
I have a 1976 850 HP Thunderbolt which I just drained the lower end oil on. I looked up the torque spec for the drain and fill plugs and...
Aug 18, 2025
Engine overheats after water heater failure
If your sure the gauge is close enough to be correct, than there is a blockage somewhere and the water heater was just coincidence
Aug 18, 2025
M
mike97520
Console Wiring 1996 Sea Swirl Bowrider 201 Limited Edition
I have had the boat for over 15 years. I didn't use it last year due to a dislocated shoulder and surgery. I have tried both ways with...
Aug 18, 2025
kd4pbs
No reason hooking the water heater gozinta to the water heater comesouta would make it overheat. Just bypass the water heater with a...
Aug 18, 2025
Is A I a totally unreliable function ?
and on August 29th, Skynet became self-aware at 2:14am Eastern time.
Aug 18, 2025
Oil Pressure Sender failure modes?
the free jet ski will cost you plenty of money. did you get a remote for the lift? we talked about that almost 3 years ago. however...
Aug 18, 2025
Scott06
Swap mercruiser 5.0 for a 5.7
yes zero issue keep the gen 2 drive and transom housing 5.7 should drop in
Aug 18, 2025
tango13
Thermostat/temp
My temp gauge for my 7.4 doesnt have #s, just low and high. Mine always is a tad over the middle - no clue what temp its saying, but I...
Aug 18, 2025
A
airshot
AI is what will destroy human kind as we know it....this will be making decisions for us just like our gov't does....big brother knows...
Aug 18, 2025
A
airshot
reacted to
jlh3rd's post
in the thread
with
Like
it's a tool....for some it's becoming an emotional crutch. For crooks, it's enabling warp speed data theft attempts.
Aug 18, 2025
A
airshot
cowl air inlet on mercury 9.9.
Usually in the rear of the cover, made to be a lift handle for tilting the motor. They also act as an air opening if you look carefully.
Aug 18, 2025
