S
svonadym
reacted to
alldodge's post
in the thread
Alpha1 Gen2 Oil Reservoir Missing?
with
Like
Welcome The A1 G2 drive does come normally with a lube reservoir bottle, and is placed at front of motor. Look at the transom inside...
Aug 18, 2025
A
aidanmurphy
replied to the thread
2003 Mercury ELPTO won't rev above idle
Got to check out the boat today. The throttle linkage bar is slipping out of the bushing that has the roller for the carb plates. Going...
Aug 18, 2025
S
svonadym
reacted to
Fun Times's post
in the thread
with
Like
Though rare, there are some (mostly 3.0 models) that had the gear lube oil reservoir as an option and sometimes it seemed dependent on...
Aug 18, 2025
S
svonadym
reacted to
Scott06's post
in the thread
with
Like
Some early ones did not have a lube bottle.
Aug 18, 2025
Z
zuchero
LOWER END OIL CHANGE
Thank you ALL!! I will go with the thread diameter
Aug 18, 2025
Don't have one that old. Checked Mercruiser Alpha and Bravo and they are 40 in-lb. The Verado OB is 100 in-lb This manual list 55...
Aug 18, 2025
S
svonadym
posted the thread
Schematic Diagram for Vintage Faria Tachometer
in
Electrical, Electronics, Audio and Trolling Motors
Hi all! I suppose this is a long shot, but my new-to-me 1993 Bayliner Classic (1952CN) came with a Faria Tachometer that doesn't work...
Aug 18, 2025
J
Jeff J
It might be a generic torque table item for the thread diameter and pitch if the plug isn’t specifically called out.
Aug 18, 2025
Starter Issues 1998 4.3 mercruiser
I don't think it's the starter, it's something else Did you rotate the motor enough by hand to look at all the teeth on the ring gear...
Aug 18, 2025
1986 Ski Nautique 2001 resto project
Look forward to seeing the progress, and right ow is a bad time at iBoats because pics cannot be posted. We all hope that gets fixed soon
Aug 18, 2025
M
MikeSchinlaub
Says the man who forgets how itchy fiberglass is :)
Aug 18, 2025
Lower unit oil leak through weep hole after impeller replacement
Might be other than the quad ring hole. Is shift shaft seal good, pump housing leaking?
Aug 18, 2025
On throttle up the engine dies
Might be fuel might be spark but need to do some testing Being a 1995 you might have EST ignition but might have TBV, motor serial...
Aug 18, 2025
Console Wiring 1996 Sea Swirl Bowrider 201 Limited Edition
This is typical helm wiring
Aug 18, 2025
A
Applecorps
Partsvu - are they legit and OK to buy from or?
Terrible customer service with a clear goal of not resolving problems. Will never buy from this shady outfit again.
Aug 18, 2025
