B
BRICH1260
replied to the thread
2006 volvo penta 5.7 rebuild help
When I replaced my 5.7 gxi, I went with a new Michigan Motorz long block. I transferred over my intake and exhaust, PS pump, alternator...
Aug 18, 2025
T
TRH299
posted the thread
1986 Ski Nautique 2001 resto project
in
Boat Restoration, Building, and Hull Repair
I haven't posted here for a long time since I finished my Larson restoration some years ago. We have been enjoying it a lot...
Aug 18, 2025
M
muc
No Trailer and Trim Up
There were two 3 button switch's. Early models you pushed just one button to trailer. The later required you to push two buttons at the...
Aug 18, 2025
kd4pbs
reacted to
DeepCMark58A's post
in the thread
Had a heck of a day
with
Like
Burned 50 gallons of boat gas yesterday the 3 person tube is destroyed but the boat did not miss a beat. I was a little concerned with...
Aug 18, 2025
A
AussieB
Is it only a matter of time for leaks?
I did some quick research and it was mainly positive, but like anything I'm sure there are also negative. Not even sure how well an...
Aug 18, 2025
Console Wiring 1996 Sea Swirl Bowrider 201 Limited Edition
universal kill switches have 4 terminals. you use the one side for powered ignitions (I/O's) and the other side with magneto ignitions...
Aug 18, 2025
redneck joe
Otherwise that's a nice boat and price seems reasonable.
Aug 18, 2025
redneck joe
Check out opinions on the opti motor, seems like not preferred but dont take my work for it.
Aug 18, 2025
R
runninfarmer
posted the thread
Lower unit oil leak through weep hole after impeller replacement
in
Mercury MerCruiser Sterndrives & Engines
Hi All, I recently replaced the water pump on my Alpha one, Gen 2 drive (2002 year). I also replaced the quad ring seal. After I got the...
Aug 18, 2025
MyLord
posted the thread
On throttle up the engine dies
in
Starting the engine and it has idled and warmed up for a while... with temp good .. I add throttle but the engine only gasps and dies ...
Aug 18, 2025
kd4pbs
Fuel Sender Leak
Permatex #2 is rated for contact with fuel. No silicone is.
Aug 18, 2025
FreeBeeTony
2003 YAMAHA 225HP 4S
Went to look at the boat today, not in the water. Can't really tell if the exhausts have been worked on or not. Is it realistic to say...
Aug 18, 2025
A
AussieB
Those are all good points, on both post's. I saw this and had thoughts of turning into a bow rider with twin consoles from a junk boat...
Aug 18, 2025
kd4pbs
Just finishing up this task on an '03 Regal 2400LSR. Hopefully splashing the boat this coming weekend to verify the outdrive functions...
Aug 18, 2025
wvmedic
posted the thread
1995 Evinrude E90TLEO charging
in
Johnson & Evinrude Outboards
Hello, I have a 1995 E90TLEO Evinrude and have a question about the output charging volts. I just got back from a remote Canadian...
Aug 18, 2025
