B
Bman2895
replied to the thread
New to me 18 hp Evinrude.
You do? I've always had luck just popping them out and if needed snipping the end of the plug wire and putting it back in. But then...
Aug 18, 2025
7
78 Thompson
Rear main seal 5.7
This is my serial number OK012416
Aug 18, 2025
B
BOYS & TOYS
reacted to
AussieB's post
in the thread
Is it only a matter of time for leaks?
with
Like
I've read enough of the rebuilds and know how projects creep and agree your timeline is more realistic. So do the 80's boats have pour...
Aug 18, 2025
B
BOYS & TOYS
reacted to
BWR1953's post
in the thread
with
Like
Or months... maybe more? :ROFLMAO:
Aug 18, 2025
B
BOYS & TOYS
reacted to
redneck joe's post
in the thread
with
Like
Age adjusted can be a couple weeks...
Aug 18, 2025
R
But you have to remove the magneto plate in order to properly install new coils !
Aug 18, 2025
B
BOYS & TOYS
reacted to
redneck joe's post
in the thread
with
Like
Sheet and angle aluminum with a thousand or so rivets and you can customize to your heart's content. Just find a boat windshield the...
Aug 18, 2025
dolluper
2014 GMC Sierra AC
High side switch has valve below it I believe you have air or charge is off...l usually introduce oil threw yellow line as most...
Aug 18, 2025
M
Mc Tool
Is A I a totally unreliable function ?
Another AI thing is some of the captions on tv where its obvious that AI is converting voice to written when we are told that someone...
Aug 18, 2025
nola mike
Oil Pressure Sender failure modes?
I am aware. project with the boy. figured it would be relatively simple, carb'd 2 stroke, right? "all it needs is a battery". and then...
Aug 18, 2025
B
billhig
cowl air inlet on mercury 9.9.
Sorry, typo 1999 9.9, serial number OG889354
Aug 18, 2025
B
billhig
The lift handle is sealed.
Aug 18, 2025
C
LOWER END OIL CHANGE
You will want to install new fiber washers on the two plugs. Make 'em tightest as possible with a screwdriver. A couple of taps with...
Aug 18, 2025
R
robertw007
69' Whaler Nauset
Ew. I did have the console and rigging on it but I can't see that weighing 240lbs. Maybe 50 if I'm being generous. There's a small lake...
Aug 18, 2025
M
Mc Tool
A .040" or 1mm spark on the plug while holding plug against the block is one thing but when put under 125-ish psi compression (thats at...
Aug 18, 2025
